QUOTE(fangjunning @ 11/12/07, 02:53 AM) [snapback]276338[/snapback]
Hi, I am learning wrap deformers and just found the wrap node disappeared when I deleted the history and the deformer was no longer working. Should this be right?
Yes, deformers are history too. So saying delete history is quite explicitly saying delete that too. You can off course ask maya to delete non deformer history only or manually do the deletion and delete whatever you want.
The purpose is to flush whatever you have done to make it permanent. You dont allways use all the deformations as animation tools. When you go animating you only want the few things you absolutely need, nothing extra.
