I have successfully applied texture maps to my polygon model but I haven't been able to figure out how to actually delete the projections. I just have to select the faces and apply another planar projection but that means the channle box lists 12 projection instead of the 8 I only need. CAn you delete them safely in some other window? I didn't see that question answered in the Learning Maya 3 book? I have Maya 3 on Win2000.Thanks!
View my Maya project progress at:****http://www.allenagenda.com/projects.htm*****
In the hypershade try Edit->delete unused nodes. This will remove any node that isn't assigned to something.
Hope this is what you mean.
ww
"It's lonely at the top, when there's nobody on the bottom"... Rodney Dangerfield
Okay, you have only two ways to do so : delete history and reassign projections, or look at the history tree of your object in the hypergraph, and try to deconnect projections from the history. I highly recommend you to duplicate your scene before playing with history and hypergraph, but this is the only way I see to get rid of those projections. Hope this helps
Alban
It sounds like that may be the ticket. I guess I will have to be more careful in placing thoseprojections.Thanks for all of the replies!
If you are transferring projections at all find the the copy/pasteProjector scripts available in the scripts section. It will allow you to copy a polyProjection and re-apply it to another object or selection.
--JeffD
