Delhistory
Hai friends
i want to delete(deleteHistory), selected inputHistory
ie, if i select the object and use deleteHistory all the history is deleted but i want the selected history alone to get deleted.
Is there any possibility to do that
If any one know kindly reply
Thankyou
Well yes its possible. You must jsut fill following constraints:
  • Theres a shape object that can hold the state at the point where you want to cutoff the history
  • You don't cut history in between a history chain, that cant be expressed a single tweak
  • Now A case is always solvable by inserting a intermediary shape in the history chain, assuming there inst one. Off course it needs to be of appropriate type. All you then need to do is disconnect the inbound connection and delete the nodes on the other side of the connection.
    Case B is trickier, but can be done in almost similar fashion as A with the exception that you insert one at both ends f the chain compare their difference and feed that to the tweak of the last of the 2 shapes, then connect the last chain back and delete the extra shape node taht was there to compare difference. Problem with this is that theres no intelligence to this chain so its stupid in many ways but usable.
    hey there arunspooja, I think what joojaa meant to say is:
    In theory - Yes.
    In Practice - No.
    :nathaN
    Well... maybe. more in line if you can describe the situation well enough yes. Problem is that people have far too much allergy against history than anything else. Deleting it rarely speeds things up, it just saves some memory thats all, if its not updated ist not evaluated anyway.
    But yes A is inbuilt in maya its called delete non deformer history. Tough you can do it manualy better.
    Hai friends
    thanks for the reply joojaa and Naughty
    i couldnt participate in this discussion
    as joojaa said, i asked about case B only, that is to cut history in between a history chain
    so, its not possible to do it.
    Thankyou
    In certain cases its possible depend on whats hppeningneing BEFORE the part you delete, and if you can diecribe what is to be deleted a linear operation of somesort (eiher in local, wold or normal space), therws still going to be A node between but its better tahn having 10, if you realy change stuff before.
    Tough its often easier just to rearange stuff
