Im looking into buying the Dell XPS 1710. Its less expensive than the M90 and it seems like the video card is better. BUt Im pretty lost when it comes to hardware, and I know that I want to be able to use photoshop, maya, and Illustrator at the same time. Im an animator who is new to maya, but I have been working with it nonstop for the last 4 months. Thanks to any1 in advance who can help me out. Here are the specs, as listed at the 4 main configs that Dell sells:
if you plan to do this for a living get a workstation your tendonc ancd neck ill thank you later.Secondly you shouldnt consider viasta yet as you get sub par perofmance out of you gfx card
Anyway none of thees a have a very good gfx card.
Im dont understand what you mean. I should get a workkstation comp running windows vista? I know what you mean about the tendon, though. I already wear a wrist brace. Is there a certain setup that you recommend? Are you using a workstation?
Well in vista you will get 15%-100% less 3d performance depending on gfx card and not much else in return than more problems and a nicer gui. This is because theres a fundamental flaw in design of all gfx cards par those that are workstation ones, even then they dont have ready vista drivers.
Anyway if you work extended hours on a 3d computer consider getting a work station because its much cheaper easier and POSSIBLE to get ergonomic equipment. As ergonomic is things that are stationary such as a good chair, its not necceserily possible to move it about. And in 10 years time you will be appreciating this aswer. It may seem like expensive now but jyst wait till it kills your motor skills THEN ITS UNLIMITEDLY EXPENSIVE. Also keyboards or meouses or your feeton laptops tend to heat up nastily (the name laptop is in contradiction most oens heat so much that you cannot keep them in your lap).
I know any people get a laptop because of some coolness factor involved, however please consider high end computing as energy consuming so you wnt end up doing much 3d on the move anyways. So if you think it in terms of its nice forget it. Because at those prices you can easily get 30 inches of display and a very good high speed redundant disk setups.
ive conceived only one very rare iuser group that would need a workstation replacemant laptop. and thats the highend consultant even so hes aware thet the workstation laptop isnt mobile in common sense of the word, and evne he would opt for a light medimu tech laptop + workstation isntead.
so if you really need a laptop consider getting cehap one and a killer workstation.
PS yes im using 2 workstations 3 servers and 2 laptops at the moment (1 is for security reasons). Tugh only the one im sitting with is what a key into im still using all of them at once.
