Hi all,
when I was scripting with mel I used to setup a button that sourced the script I was working on and executed the main procedure.
e.g.
source myFile.mel;
foo();
but if I try the same with a Python module this approach obviously does not work too well.
The first time I execute
import myFile
myFile.foo()
everything is fine. But if I make some changes to the code they are not taken into account, when calling the buttion a second time.
The problem persists even if I use
del myFile
and then reload it after I made some changes to to the modules code. PythonMaya will still executes the old code.
Do you have any suggestions how to set this up properly? Or an alternative way to develop Pythonscripts for Maya without pasting them to the Scripteditor everytime something changes.
Thanks in advance
Cheers -Silvan
