Dielectrical Materials And Physical Light
I continue my post here from the modeling section. I have created a model of Britney Spears
do you have neough depth for the photos and refractions, your scale is it correctly calibrated to teh ontendsity and internal decay of the material?
I
you need to shift the color more towards white since if its pure red then it flters the flolor realy fast with white being realy transparent.
But yes se i mean the globals, the reflection/ refraction and max trace depth and max shadow trace depth as well as max photon depth etc basicaly all the things that affect iteration ddpeth and have depth in thier name. The scale does affect physical light in a big big degree. ITs not uncoomon to need to set 1000000 as the intensoty for stuff.
Thanks! I changed the scale and now I can adjust the intensity of the light. Earlier I was down to 0.01 and it was still overexposed! I also got the transparency to work. As you can see in my latest render I have changed the color to the real perfume bottle
