I have got some very good and clear polygon (4sided) models, which i have to cut with boolean operations. After cutting, nearly all polys (not only the affected ones at the border) are divided into 3sided polygons. Well , after removing thousands of edges and freezing the model, i still have this huge model-operation-list in the explorer. Opening or copying takes a lot of time - it seems that xsi always has to remove the edges again?
Just a thought, did you try freezing your construction history? just select the object, and hit freeze
Olivier Ozoux, SOFTIMAGE Special Projects
The opinions expressed in this forum are my own, and might not represent's Avid or SOFTIMAGE official position on the subject.
