Dirtmap Shader For Maya 7?
I can only find it for Maya 6, does anyone know if this will work or is there a work around in 7? Thanx
use the ambient occlusion shader teht ships with maya instead. or better yet the fg amb occlousion one. and yes they can account for bent normals. chak the newer ray nodes they largely have everything dirtmap has.
Hi!
The shader should work, you may need to change the max version value in your mi declaration!
-klaus
thanks for the replies, i wish Gnomon would do another set of MR DVD’s going a bit more in depth on the nodes.
heh, you cant be taought what you can do with nodes you can only be taought what the nodes do. Even a very good tutorial would only scratch the surface because theres ainfinite wqays to cobine nodes, some such taht even the roiginal designer didnt account for it.
Thats the idea of node networks.
