If I create a simple shape, add joints, and a smooth skin, then add a lattice deformer to the skinned object, the transform widget for that shape no longer works. It is grey, and the values cannot be edited in the panel.
Does anyone know why this is? It’s a repro of a problem I’ve actually been having with writing a plugin, but figured somebody here might know why Maya has this behaviour; I’m trying to understand what the conditions are that cause it to disable the transform widget…?
QUOTE(Morny @ 10/02/08, 05:54 PM) [snapback]292713[/snapback]
You can re enable it. BUt since the data is now controlled by BOTH the transform of the latice, skin etc etc and your transform it would lead to double transform so maya tries to limit your possibility for that by underlining the fact. So instead of getting the object go besrserk your guided to use one place to move it form.
So if you say follow the dog and follow the cat you end up getting NEITHER of those follows but something way different. Thus maya says keep the dog stationary.
QUOTE
widget…
Maya locks the channels widget is called a gizmo or usually tool and its disabked because theres no data to manipulate bacause they are locked.
