Hi,
How can I select low and high poly in the extract texture maps dialog box? Because I select the level 5 in the object list and hit the add button, the same name appears in the high and low resolution settings box...
thank you
Mudbox will take the low resolution version to project your displacement on, So you use the same model twice, just not at the same subdivision level.
