It appears that MRFM won't apply a displacement map to blobby-rendered particles. (Or any particle render type - doesn't work with spheres, either.) Is there any way around this?
I don't know about blobbies but you can probably use the particle instancer or a script to copy geometry to the particles for regular shader effects.
QUOTE(gmask @ 01/09/08, 04:53 PM) [snapback]279472[/snapback]
Unfortunately, that's a no-go. Need to render as blobbies.
