Display problem with Maya4 and GForce2 Mx. HELP!
I have a GForce 2MX Elsa Gladilac, I used it with Maya 3 with no problems but I have display problem with Maya 4.
When I apply textures, the object become semitransparent.
Is there a new setting I don’t know about in Maya 4 or I have problems with my card?
Thanks
My GF2 MX works perfect with maya 4…
(untill I use more then 5 polys that is .
but I never had that problm with Semitransparancy…
I don’t understand, this transparency apears only when I enable hardware texturing
I have encountered the same problem. The Maya 4 release notes make mention of a bug that appears when in h/w texture view. They say the model appears in a “stippled” view. It kinda looks like a transparency or ghost-like shader has been applied to the model/geometry. I tried reapplying UV to the polygon model but that didn’t see to work. It is a pain in the but…I can’t use projections if I can’t see what I am doing. I am still looking into getting this fixed somehow.
View my Maya project progress at:
http://www.allenagenda.com/trouble.htm*
I have to upgrade the card then, no other imediate solution
Thanks for your imput.
Ovidiu
I received a reply which applies to your problem, I think:
Subject Re: Polygon Texture Mapping Woes!! [re: forme3d]
Posted by alienwest (newbie )
Posted on 11/19/01 12:16:56 AM
Same thing happens if you apply a file texture to a beveled primitive poly. Try this . . . Create a primitive poly with a shader that has a file texture color. Now bevel the poly. Whoa!
Now select something simple like automatic mapping. Presto!
The logic (I suppose it’s logic) is that if you bevel it, you lose your UV’s. So, therefore, for some reason I suspect that’s what’s happening to you.
Solution: remap after applying the texture. Pain in the butt, but it should work.
I will try this.
Thanks
