what i have in mind is i want to create a script/plugin, to record the movement of the hand(mouse, wacom) as keyframes on whatever that is to be animated, sometimes u can feel the timing of the motion, but can really express it, so i figured this would be a good idea..
so up till now, ive tried several methods, still within mel, starting wiith a scriptJob that runs on timeChange, and tried to have it run while the play is pressed, so that it wld record, but apparently timeChange doesnt work this way, the time change occurs when u stop playback,
ive tried to run an expression thats triggered by "time", and has a setKeyframe on the sequenec u want to apply the animation to, so when i execute the expression, also while playback is active, well it actually works, but it VERY unstable and gives very unexpected results, runs on some keys and doesnt on others, i guess i should have expected that, but i figured id deplete and give up on the mel idea first so i can do it with whatever other method there is.
so could anyone give out any suggestions about how to do such a thing? whether u had any other ways in mel, or any other 3rd party apps, just tell me where 2 go from here! thanks!
