I’m planning to overhaul my workspace at home with the addition of some new hardware. I plan to purchase the cpu and monitor this week and in a couple of weeks get the Cintiq. My main apps are Maya, ZBrush, PhotoShop, Painter and After Effects. This is what I’ve spec’d out for myself but I do have some questions about this configuration.
_____________________________________________________________
BOXX 8300
Two DUAL-CORE XEONS 5130 2.0GHz, 4MB cache, 1.33GHz FSB
Intel
Cool man, thanks a lot for the helpful reply.
What sort of change (spin) are we talking about concerning changes to the 5000x chipset? It’s my understanding that the quads will use socket771 (socket-j) as well. Do you know of any online resources with more definitive information on this change and it’s time table?
Much appreciated.
'cel
QUOTE(MarcelH @ 08/10/06, 08:32 PM) [snapback]244853[/snapback]
Much appreciated.
'cel
sorry, I am not sure about the exact time of the hardware spin. it is part of the chipset change. so it also depends on what Boxx uses for MB. every MB manufacturer has its own chipset supplies, so it would be impossible to find out w/o going to them. if Boxx uses Tyan, then you will need to find out which model (MB), and check with Tyan.
I also want to clear up about the hardware spin. there is no physical difference between the boards. it is almost like a firmware change, but can not be flashed.
example here. the latest Intel workstation D975XBX mb: http://support.intel.com/design/motherbd/bx/bx\_proc.htm
if you look at the link, you will see that you need the latest MB with certain AA number to support new Conroe CPU. If you bought this MB with all prior AA number (shipped before April, 06), there are no support for the Core 2 Duo CPU
How about using a new Mac 3gb Intel system?
Hey bellwilliam, thanks again, guy.
To answer your question imagineeruk, I’m mainly buying a box for 3D right now. The tools and support just isn’t there yet for Mac as far as 3D goes. In addition, I prefer to run all wares on their intended hardware. Professionally, I feel it’s the better way to go at this point in computing. Don’t need any surprises in the eleventh hour if you know what I mean. I do however plan to upgrage my Mac towards the beginning of next year once I got my new PC station up and running. … Completely redoing my studio is basically what’s happening.
Thanks for the suggestion,
'cel
