I just got my nice new monitor, and I tried to use both on my Radeon 9700 Pro with maya, but for some reason, the maya window doesn’t stretch all the way over both displays. I can drag floating windows over to the second display, but I can’t draw a bow to select, the render vew doesn’t update and soforth.
On the other hand, when I work in Photoshop, Combustion or Shake it works just fine, and opens up on both screens by default.
So I guess it can’t be set up that wrong.
Any idea how to get it running properly?
I’m using the dual outputs of my Quadro 4 and what I just do (personally) is tear off a copy of the perspective (or camera angle) viewport and make it full screen on my second monitor. So on my left monitor it will be full screen Perspective/Camera, and on my right monitor it will be Top, Side, Front and either the Hypershader, Outliner, Hypergraph, or whatever else I need.
ensure that you are not using dual view; and instead twinview span inside the twinview settings
dual view doesn’t support openGL on secondary displays
I actually just talked about this with an ATI Engineer last week. Their dual display drivers are pretty buggy for 3d apps. They are working on improving them but it sounds like it will be some time.
Meanwhile nvidia’s are working quite nicely ![]()
I had the exact opposite problem though. nView wouldn’t do OpenGL on the second display but DualView would. Widnows 2000 btw.
Hi,
Ati cards with current Radeon chips have a visible 3D window limitation of 2048 x 2048 (or something like that). But you can have more 3D windows open at the same time.
My suggestion:
Open Maya on one monitor and then tear off copy any 3D view or use Hypershade, Hypergraph, TraxEduitor, etc. on the second monitor.
Best,
HumHum
From what I’ve understand Radeon drivers should have an option to use 2 monitors while windows detects 1 monitor. I’ve never used ATI so can’t tell you how to find it exactly. This option is available in Nvidia (it’s called Span there) and Matrox and I’ve read that ATI has it as well.
