I'm using an HVX200, at 720p30. I import clips using the P2 Import feature in Final Cut. I often just want to get clips off the camera and into Shake and the import feature in Final Cut seems the best way. However, when I take these converted clips from FCP's scratch folder and put them in Shake, their aspect ratio is wrong. If I put them first in FCP, then export from FCP as a QuickTime movie (without making any modifications at all in FCP), the new QuickTime movie looks fine in Shake.
I also have the same problem if I use the Send To Shake feature in FCP to send the clips to Shake. When they come back in to FCP, they look fine, but while in Shake the aspect is wrong.
I've seen the problem discussed in these threads but without an answer:
http://discussions.apple.com/thread.jspa?m...35�
http://forums.creativecow.net/readpost/154...822&pview=t
Does anyone have an answer to this problem? I'm using the latest version of everything, including FCP, Shake, QuickTime and OS X.
Thanks!
Fergus
