Edgeloop Problem again (in detail!)
Ok everyone, the last post somebody gave a very inadequate answer to my question, so I decided to explain it in more detail :
http://www.geocities.com/zerovel/prob/prob1.htmlhttp://www.geocities.com/zerovel/prob/prob1.html
The page will contain my question again with images of the problem.
Either my combine poly tool is faulty or I'm not using it correctly, i'm not sure, could somebody please help me out. Urgent call to all Maya modellers. I know for certain there is a simple answer to this but can't figure it out.
NOTE: remember to view the page @ 1024x768, I quickly used Front page to make it and it contains dotted lines which don't line up unless the browser is open at that res. size.
ZeroVel
Did you try to just mirroring the geometry?
Yes I did! mirror seems to be the same as duplicate on the negative axis then combine. Although the border vertices are merged, its not an entirely new whole mesh. You can still seperate the two meshes if you accidently play with the central border vertices. I even tried the mirror with the connect border edge marked.
ZeroVel
Did you delete the history on it afterwards?
Yes I just did that but the only the thing it does is suppress the warning about "tweaking ojbects with histories may cause undesirable effects" or something when using the mirror. I did however try adjusting the vert. at the border, some of them where not aligned properly but when completed, it still gave the crease in the middle. Either my modelling technique is wrong or something funny is happening.
Keep in mind I started off with a cube and subdivided it to this shape.
ZeroVel.
From what I can tell you have some tangency issues at the points were you are getting creases.
I think you mightbeable to correct them by selecting the offending CV's and selecting the up arrow and snapping the vertical placement to a neighboring CV.
Hi.
Maybe this is a stupid question.
But did you combine the two models first?
It should turn the both wire color to be green.
Then merge edges or vertices.
If it won't work, you can chose "Edit Polygons > Normals > Set to Face".
Or "Average Normals."
Finaly, Soften the nomals.
How do i select control verts on a polygon? This mesh isn't a NURBS mesh. Do you mean align the border verts to the adject verts with the "snap to points" option on the UI by moving them back and forth until they're aligned? or do you mean something totally different?
MOLE YOU BLOODY GENIUS!!!
That did it perfectly!!!!! I knew there was something missing in my process:
* Duplicate
* Combine
* Select central verts, Edit Verts|Merge Verts|0.25
Important!!!!
*Edit Poly|Normals|Set to Face !!!!!
  • Smooth
  • Presto!!!
I probly could of cut out the first 3 processes and just do a mirror but I usually do the 3 anyway
GMASK and Mole, thank you very much for all your help, this prob has plagued me for months on end with other models and it was a simple matter of setting the normals to face!!!
Here is what it looks like now:
http://www.geocities.com/zerovel/prob/solved.htmhttp://www.geocities.com/zerovel/prob/solved.htm
Again, thanks for all your help.
ZeroVel
PS I'll definately post up the end result in a week or two for all to see
