Editing Nurbs Primitives - How do I?
Hi,
Im trying to edit a circle and add a line to it but the line doesnt attach to the half circle shape.
This is what I do:
  1. Create the circle from under the curves tab
    I remove half of the circlle by deleting points.
    Im now left with half a circle.
  2. I create a line with the cv curve tool making sure that one point overlaps the end point of the circle.
  3. I go mental because I cant make the 2 shape (line and half circle attcach)
Pleas eplease help me!!!
Many thanks,
Matt
I would like to know how did you manage to make a half of the circle by just deleting the points? I can't do it.
I just selected some of the circle pressed F8 and deleted some points i err i think thats how i did it. Maybe thats wrong can someone exmplain how to edit a primitive?
What do you mean by "edit a primitive"?
Hi,
I want to use part of a cirlce shape to make another shape but cant break it apart to form another shape.
how do I edit the shape/curve so i can add a more curves to the circle for exmaple if i wanted to make a heart shape I would use 2 cicles and remove some points and a a couple of lines (this is only an exmaple i would probably just create it using cv curve tool).
Does that make sense?
Cheers,
Matt
Yes, but what's your question? As things are now your question would require answer that is several dozens of pages long and which is btw already written and is accessible to you thru manual.
Simplay mate:
How do i edit a primitive so i can extend/change its shape?????
Simply: You use combination of various tools and commands. What is not clear here?
Can you exlpain how I edit a cirlce primitive?
How would I add a simple line?
I can give you the recipe how to achieve what you initialy asked. But this is not what you really need. What you need is general understanding of how curves work. Otherwise you'll stuck again it the similar manner. And again, and again. So please, spend some substantial time browsing and reading maya manual and trying out concepts described there in practice using your own little examples.
  • create nurbs circle with number of sections set to 8
  • right click on circle and select "edit point"
  • select two diametricaly opposite edit points
  • Edit Curves > Detach curves
  • select one half and delete it
  • create arbitrary curve using cv curve tool.
  • right click on curve and select "control vertex"
  • select one ending control vertex
  • switch to move tool, hold down the 'c' key and middle-drag over the half circle until you have two curves touching at the ends
  • right click on curve and select "select"
  • select both curves and go Edit Curves > Attach curves
  • Edit > Delete by type > History.
thanks
