EE: channels locking/unlocking each other?
Hi there,
I have a question;
is it possible to create an expression which ensures that when the value of a certain channel is < then X a different channel will stay locked.
For example, I have these 2 channels;
    If the 1st channel, called "eyes_digits" (Float: min val 0, max val 10), < 10,
    the second channel called "eyes_expressions" (Enum: 6 possibilities) is locked.
        Else, if channel "eyes_digits" = 10, (or == 10??)
        channel "eyes_expressions" is unlocked.
  • I am working in the Expression Editor because I want it to constantly check the 'if statement'.
  • I want to use this because the 2nd channel should not be keyable while animating if channel1 is has a lesser value then 10.
My current expression looks like this... It doesn`t update (constantly check) and only works once after 'editing'...
I am a nooby at scripting, it was just an attempt:) here it is;
//Expression Editor Script Example
if (cc_expression01.eyes_digits < 10) {
    setAttr -lock true cc_expression01.
eyes_expressions;
}else{
    setAttr -lock false cc_expression01.eyes_expressions;
If anyone could help me out I would really appreciate it!:slight_smile:
Thanks in forward,
Mark
Expressions only evaluate when the time changes, or when you edit them. You need to use a scriptJob that triggers when an attribute changes.
global proc myProc() {
    if (getAttr pCube1.translateX > 10) {
        setAttr -lock true pCube1.scaleX;
    else {
        setAttr -lock false pCube1.scaleX;
scriptJob -ac pCube1.translateX myProc;
