Elliptical Filtering with MR
I have not been able to get elliptical filtering working with MRfM under Maya 5.0 After following the steps detailed in tutorial written for MR w/ Maya 4.5, which uses the same functions that are shown in the Rendering with Mental Ray book, I still get errors. Anyone have any success getting the elliptical filtering to work? If you have, and would be kind enough to share how you accomplished it, I would really appreciate it.
                                   Josh
its the same workflow... make the same connections...
btu when it comes time to make the fileTex nodes... make them through the custom entity - custom texture section of the renderGlobals...
instead of writing the name file1:tex in the space provided for the texture... you will only need to write file1
there are some additional attributes now available to the textures created through the globals.... in the extra att section... including a filtering based upon a texture size approximation similar to mip map...
r.
SamOfSon-
You rock! Thx very much for your help, works perfectly. I knew it had to be something lame that I was missing (and it was) b/c the workflow couldn't be that different than in MR standalone. So anyways, thanks again.
Josh
