Hi
Once you have installed the plugs, select them in the installation directory & get Properties (Alt+Enter). Make sure that they are not marked as Read Only. combustion* needs to write to the actual plugin file to serialize it, so if it can't do that you'll get an error.
Good Luck!
Dave
