Essential mel script that is unavailable...yet
Ok, I know a lot of people are doing squash and stretch rigs these days.
The typical problem is creating a set of arm or leg joints with the ability to scale once the IK has extended past the length of the joints.
At two different FX houses I have seen expressions that measure the joints or angle of the joints and scale the joints properly to meet the ik hanfdle, then when the IK handle returns the scaling turns off and the IK resumes solving.
Ideally you can even overscale the joints through a separate attribute thus maintaining the ability to have a bend while scaling towards the IK handle.
If only one of you smart Maya users would solve this expression creation through a mel script. That way, people could rig an arm or leg, run a script and get stretchy IK limbs! Oh that would be the ultimate.
That and something to mirror a characters pose! If you could mirror a pose easily, you could make walk cycles in a matter of seconds. Start with a contact pose key, then a passing pose key, mirror key, mirror key viola! A base walk cycle!
Yes many of thees things are doable with snmart rigging... And its all up to the maker of the rig to implement theese. Mirorring poses isnt realy that hard except that when it comes to making them work on every rig when it gets problematic.
but scaing the limbs isnt hard at all just scale the bone!
Mirroring the pose can easily be done if you can cotroll the naming convetions or someyhing like that but making the mel script global is a totaly different matter!
