Hi Frnds
I have another one question
isit possible to export a UV of one object and i want import this UV to another one scene
isit possible or any scripts already we can get ???
thkx for your info
regds
Kurian
Hi
Is is not possible in Maya ??????????????????????????????????????
o.S.k
well export the history deleted char imprt it do a uv trasfer and delete the temporary char. BUt yes it is doable.
Hi Joojaa
No other ways now isit ???
well yes you can try to just copy over the transfer node it will contain the data. You can allways delete it later! THis owrks like spiff fro most maya nodes that store their values. I doe it all the time for copying blendshapes form scene tos ecene. just take the blendshape node and swithc it to the new on with new blends.
Hi Jooja
Yes this way we can do ..after that we can use Transfer UV ..so it will workout
but scene will come heavy for some time anyways now i can use this way
thanks for your great help
Se thing is if you input the transfer to the right plce you can allways delete the node later since its job as datatransferral is done!
QUOTE(Joojaa @ 02/21/06, 10:45 AM) [snapback]228896[/snapback]Se thing is if you input the transfer to the right plce you can allways delete the node later since its job as datatransferral is done!
Yes joojaa..its corect i can delete at anytime so its working now
o.s.k
