QUOTE(Joojaa @ 03/17/08, 11:37 AM) [snapback]282742[/snapback]
make dure direct connect is loaded.
Anyway ods are the iges is correct your target app just doesnt read it right. (iges as a format IS a nightmare, in fact ALL 3d date bebelization is nigtmare unless you wirte the outputting module yourself.)
The real question s WHAT d youu intend to do with the data, now we are stabbing your latest incarnation fo the problem. Odds are you made the mistake in thinking at step 1. Its easier to fix your thinking day 1 than day 365 on theway.
So what application is the target.
points or interpolation?
Need to get into our CAM Software. VCarve Pro (dxf eps ai pdf pvc v3d v3m) for 3d cuts we use cut3d both from varitec. Im going to try to bring the dwg into solid works and see if i cant get the curves because right now it seems the DWG Exporter linked wont contain anything but actual geometry.
See the goal here is I have a organic surface and im projecting curves on it. So those curves im now taking and cutting them as flat files on a 3 axis CNC machine (Shopbot) the goal is to make a giant wireframe version of the shape. So far IGES seems to support curves but every where i look i see problems with interpreting the iges file when bringing it into another program and it holds true for me unfortunetly. The old exporter in 6 use to work fine in dwg but i just dont get why they dropped the curve support.
And to answer your question IGEN the curves come out fine its the placement thats wrong. I have 40 curves that need to be exported and all in their exact X&Y positioning so when i build the tool path the notches that will get cut will all line up perfectly or i have no way to register them.
