Export to .3ds in Maya
Is this possible with a some kind of plugin or built-in function in Maya? The only solution I could find was a very expensive program.
Hi.
I don’t know anything about Max.
But… doesn’t max have dotXSI importer?
If so, you can get free dotXSI plugin for Maya from Softimage website.
Or maybe there are better ways.
Go to www.righthemisphere.com
They used to have a plugin called the .fbx plugin (filmbox) which is a go-between format that can be read by both max and maya.
If you don’t have a copy of max, just a .3ds you found somewhere, then check out their package called deep exploration. This will convert .3ds to .max, .mb, .obj, .lwo, and loads of other 3d formats
You can download a 30 day trial demo from them.
If you do have max, you could export the .3ds as a .dxf
Maya will import .dxf
This format does not include animation data though.
