Mobo: Gigabyte GA-7DPXDW
Processors: Dual AMD 1900+
OS: Win2k SP3 on 8.5GB partition (IDE)
HD`s: IDE 1x 30 GB 7200rpm Western Digital (8.5GB/19.2GB)
RAID 2x 120GB 7200rpm Western Digital 8MB Cache (7x30GB/1x15GB)
When I tested the Drive speed it said it was getting on average 57,000kb/s on an empty partition and around 39,000kb/s on a 3/4 full partition… yet my system often hangs when writing any video file type from any video software… avi, mpeg, mov… and i tried different compressions… you name it, it hangs… and I have to reboot.
and Im gonna be without the ocmputer for over a week cos Im moving to the UK… n taking it with me so i`ll have to get back to this issue when I have it set up over there.
hrmm ok I havent packed up the computer yet so.... All I was able to use for a quick drive test was Nero Burning Rom... I currently dont have any proper testing software installed yet.
Nero shows my 32x CD Burner as capable of 4,800 Kb/s this would be 4.8Megabytes a second right?
Nero shows my HDs as capable of 57,000kb/s when tested so assuming they are using the same thing, kilobytes per second, wouldnt that mean it is in fact capable of 57Megabytes per second?
EDIT: I just checked the speeds again… after completely emptying one of the 30GB partitions and it shows the speed result as 68,000KB/s, I think it being shown in upper case may also signify it is Kilobytes and not Kilobits… right? I`m not sure though…
By the way I haven`t had a chance to try the memory thing yet…
don’t be…lot’s of folks don’t know -just because nobody ever explained it to them…
Now it gets really [censored] up -
There are 1024 Megabytes in a Gigabyte, not 1000 as one would guess.
That is the reason that when you put RAM in your computer and turn it on, the BIOS boot screen never indicates the amount of RAM you thought you installed…
