QUOTE(failure @ 11/06/05, 07:59 AM)
pCube1.rotatePivotX = circ.rotatePivotX;
pCube1.rotatePivotY = circ.rotatePivotY;
pCube1.rotatePivotZ = circ.rotatePivotZ;
Note that this operates in local space of both transform node and it's probably not what you want.
You should just connect the rotatePivot attributes via pointMatrixMult nodes ( to transform source into target's coordinate space )
This is mel, not an expression. It should be run once and it builds node connection:
polyCube -name "pCube1";
circle -name "cir";
createNode -n pmMult1 pointMatrixMult;
createNode -n pmMult2 pointMatrixMult;
connectAttr cir.rotatePivot pmMult1.inPoint;
connectAttr cir.worldMatrix pmMult1.inMatrix;
connectAttr pmMult1.output pmMult2.inPoint;
connectAttr pCube1.worldInverseMatrix pmMult2.inMatrix;
connectAttr pmMult2.output pCube1.rotatePivot;
I'm just curious why would you want to do such thing? There's absolutely no need forĀ this whatsoever. Not to mention that this kind of thinking generates unwanted loops in dependency graph.
[snapback]218967[/snapback]
Thanks again for the help... I realize that it could create loops that could be bad, but if you are careful on how it is set up, it will work just fine. The reason that I want to try something like this is so that I can control the point for which an object rotates, based the location of another object...
so for instance if I am setting up a foot rig, and I want to rotate about the ankel, then I want the rotation point for the toe (or the tip of the foot) to move with it. Then I can rotate about the toe as well even after I have rotated the ankle... Its a tough one to explain, hopefully you see what I'm trying to do..
The one thing that I was hoping for in Maya 7 was a sort of "Action Center" like Modo supposedly has. That way you could make multiple pivot points to rotate around and still have all of the controls go with it.
Thanks again!
