I renamed the polycube in the mesh node type window of the attribute editor
and I renamed the nurbssphere in the nurbssurface node type window of the attribute editor
when I typed in the 1s -st Sphere Cube in the expressions editor command line I got: 2 expressions
but I havent bene able to replicate that
when I type it in the Mel command line I get syntax error
I tried closing it down and reboot it, creating a new scene
created a new sphere and cube, renamed them as before
and when I typed in the same command in the expressions editor I get syntax error
ditto
I notice that even though I changed the names of the items,
in the upper line at the top of the maya window frame , where it says Maya 7.0/untitled--nurbSphere1 and pCube1 when I click on the object
even though the mesh is defined as Cube nurbSurface as Sphere
and the same is true in the expressions editor , the object is referred tio as PCube1
