Extruding Subdivided Polys
Maybe I'll try this again. Why wont the offset command in extrude face work on subdivided polys? I get weird results depending on which surface I choose. Try it, make a ploy cube>select all faces>subdivide them into quads>select all the faces and extrude them with a slight offset then examine the extrude faces. The offset extruded faces will be correct only on one side while the rest of the sides will perform differing results. ??
not getting that problem,
are you sure your "random" is off?
Your telling me you subdivided a poly cube face into quads, extruded the four faces with a small offset and they all came out symetrical? I can only get that to work on one side of the cube. Try it on other sides if you will. I will get two of the four extrudes to offset and the other two will have zero offset! Yes to answer your question my random is set to nil.
you are right, if you have keep faces together off. however, if KFT is on, every face offsets, only you have to do them individually. it seems that the new auto - generated polys on every subdivided face will not offset if KFT is off. weird.
