Hi
I'm having trouble extruding text.
I click on "Create" then "Text" and a box opens with various options.
The type of text IE: curves, trim, poly, bevel
Triangles or quads and the tesselation method.
I've tried a various combination but still can't get them to extrude.
Any ideas?
thanks
Hi,
I have no problem in creating text that is also extruded using the "Bevel" method. If you don't want the bevel effect, you can nevertheless use this method and turn off "Create bevel - At start and At End". The Extrude distance determines the "thickness" of your text now.
gentlesea
