Hi all. Whenever I extrude 2 faces at the same time that are side by side....they do not extrude together. they have a space in them. Does that mean I have to extrude then weld the points together after, or is there another way of doing it? thanks!
you could delete the edge that is between them first so that you only have one face to extrude. I do not know of a trick to make maya think that you want to extrude the two as if they are one.
this is very simple:in the channel box you enter "on" or "1" in the "keep faces together" field.To make this your default you select Keep faces together in Poygons>>Tool Options
