Hi all,
I am doing some face extrusions but sometimes manipulator disappear. If I press manipulator tool does not appear at all.
What can I do?
Thanks,
Dragos
Hi all,
What can I do?
Thanks,
Dragos
Select the history node in the right hand view (in the channelbox if you for some reason have any other panels there) and it should reappear if the history wasnt of on creation offcourse!
You are right. Thanks a lot. Dragos
Note thet this way you can even use manipulators of older history events so if you do extrude on extrude on extryde you can go back to the first extrude and see how it affects the whole lot!
What if the event is not appearing in the Channel Box either, but it is still happening to the mesh??
Then its probably not part of the history after all. Or it is piped trough a different shape wich would have its own history (this is visible enev in most cases). This can happen if the history chain is manualy built up or you do use some obscure tips, where maya decides that the resulting node is too far away to consider.
You can still select the node however! Either trough the hypergraph with show input output (or hypershade wich has similliar functions). Or trough the outliner if you happen to know the name of the node.
Allso if history is off then you cant for ovioous reasons acces it.
