I recommend making a face out of your wireframe. Then use Draw/attache hole to cut out the shapes for holes.
Then shade the view and select shift/i (icon) to see wireframe on top of shading.
You should now see your letter etc. properlly filled in. If not, such as a portion has missing areas, move points, handles insert points etc, until it looks fully shaded. If it shades well, then chances are the extrusion will work too.
If your bevels are inverted. Just select your wireframe and then use Effect/invert. This inverts the wireframe U values and makes the extrusion create normals on the other side,which should put the bevels on the proper side.
Hope this helps,
Urp
