Post deleted by MarsChi1d
I often wonder why so many people include the statement “I didn’t spend much time on this” in their posts. I mean either a.) You DID spend a lot of time on it, aren’t happy with the result and want something to fall back on in case people don’t like it or b.) you really did spend very little time on it and have no pride whatsoever. I think that statements like this make people think you really don’t care to have it critiqued and they’re not going to waste their time doing it.
Anyway I’m not quite sure what you want comments on here… there’s no animation for us to see this turbulence you speak of and very little texturing. Did you create the head itself? If so and you want comments on that it is impossible to see it from under the cloak. Do you want comments on the composition of the shot or the rendering?
Give us something to go on, here.
Well i will try to offer some helpful advice then.
From what I can tell, the chin looks like a victim of mirroring and merging. There are several ways to fix this depending on what type of geometry you are modelling with. Obviously he could use some textures, and the lighting would add a lot to the scene if it wasn’t behind the camera. Look for a tutorial on doing a 3-point lighting setup. Also you should take note that putting the light directly behind the camera essentially removes shadows from your scene and flattens the appearance of bump maps.
Whenever you post a model/scene for critique it is best to have several views for everyone to see.
I hope this helps!
