Facial rig I’m working on. I used smooth bind, influence object and blend shape.
http://www.sheenmasu.com/in_progress.htmhttp://www.sheenmasu.com/in\_progress.htm
Very nice.
But none of her expressions are extending into her eyes. I’d like to see her whole face change when she smiles not just her lips. There should be crinkles around the corners of here eyes (regardless of how old she is) her cheeks should maybe deform some more. Carry some of the feeling into her forehead even.
Right now all of the expressions look insincere because they only involve her lips and jaw.
-James
yes.. the smiling with open eyes is creepy..
but you can do that with more blend shapes
The jawline is also abit off, making the teeth wrong also.
Right now the jaw opperates like a straight line from the ear to the chin, when it should go down from the ear then over in a more shallow angle to the chin. this will keep the bottom teeth more parallel to the top teeth
and give a more accurate jaw line when the mouth opens.
texture of upper lip runs off a bit high for what was modeled. I definetly agree. the muscles around the cheekbones give so much character to the eyes. Well done.
-J
so you are running blend shapes on the influence object? Ive seen this workflow before for facial mocap, it is a good way to pull shapes out for blendShapes, but horrible for a good animation pipeline. It carries around a lot of history with it. I know that there are a number of studios that are achieving many advancements in muscleRigs but when it comes down to it you really just need target shapes. If they do use real time solutions at final render I would bet the animators work with it at a different level. It is definately an interesting workflow, especially breaking it out like a muscle sytem. You can actually carry the weighting and facial rig animation over to other models by dupplicateing the rig surfaces and match to another charcter then do a blend between them.BTW what kind of system are you using, how many surfaces have you used so far, and how is the performance…el diablo
Muscle sytem is a plug-in that my lead is writing (for the time being it does not do multi colliders). Most of muscle sim can be done by influence object but muscle sliding under surfaces (like tongue pushing out her cheek, shoulder blade for her back and so on) is a different story. Target shapes are useful in a lot of ways but animation of deformation looks liner even with a lot of inbetween targets. What I want to achieve for this project is skin sliding on bones, tungue deforming her lips, shoulder blade sliding under her back skin and so on. I am not using self collision for this one and in the test case I could move her face real time. I am using a lot of bland shapes and only use muscle sim where it is worth it. In my opinion you can do all these using bland shapes but since I am a character td, I want all these gadgets on my tape:)
