In your lights, you must raytraced shadows to make them evaluate the transparency of the object. If you used shadow maps, the shadow of the object will be solid, no matter what.
If you don't want to change your lighting and stick with shadow maps, then I would create a shadow-only light and animate the umbra factor of this light.
Hope this helps
Salutations - Cheers
Bernard Lebel
