I’m trying to make an effect of a cathedral stained glass window lighting the ground below it and I’m having serious problems doing so.
I’ve tried Area Light but it warps the image I map to the color channel. I tried spotlight but the light doesn’t meet up with the edge of the window, so I increased the prenumbra but then it formed a sort of halo around the mapped image on the ground.
Can anyone give me any help on how to do this? I’d be very greatful. Thanks.
Try using a directional light. Assign the image of the glass to the light color as a projection. Open the hypershade and click on the light tabs and view the up and downstream connections of the directional light. Now, in the “file” node under the “color balance” section change the default color to black. In the “place2dTexture” node uncheck wrap u and wrap v.
You can move the “place3dTexture”, which is visible in the scene, into the window opening. Move the directional light so that it points toward the window like you want.
Well I dont understand where u got the place3dtexture node from.. I’m using a file node which connects to a place2dtexture node. I tried doing what you said with the directional light, unchecking wrap u & v and trying to line the light up but nothign showed up on the ground at all…just the image of the window (which is where it should be) and the black ground, no caustic on the ground.
