Okay I had a model and was smoothing different parts of the meshes in it. Some smooth fine but the rest after I hit smooth I get "Fatal Error . Attempting to save in D:/Doc.....20080430.1709.ma" hit ok and the command line continues then when its done maya crashes.
Googling all I can find is its a video card driver problem and to disable tripple buffering and if using a quadro disable overlay. Tried without tripple buffering enabled it still happens and I can't find any opengl settings to change the overlay (GeForce 8800GTS 320) so I lowered the res as it said "or don'tt run in a res greater then 1600x1200x32bit but still crashes
Tried deleting the maya folder that gets created in my docs with the prefs and same thing.
Using the latest Forceware driver i just download and some of the meshes arn't even complex just 7000 tris etc and crash on a single smooth.
Anyone got any other idea's on how to stop the crashing and also why maya is failing to write the temp file?
Okay just tried running in 16bit colour and there's no problem at all. Obviously the driver or the card so does anyone know of a Forceware that might work? or ware i can get to OpenGL settings in the GeForce to see if the overlay makes any difference. I really don't want to have to run maya in 16bit colour as I get a terrible performance hit.
Okay installed RIvatuner and got access to OpenGL settings and seems overlay is a quadro only feature so it rules out that being the problem.
