Hello,
I am using the "send to" option in 5.1 FCP to 4.1 shake. It always sends the wrong clip to shake. I have selected the clip correctly but it never works. I will load a random clip sometimes several minutes away from the intended shot. I always have to export from final cut into a folder and back into shake. When i send the same clip to Motion it works great. What is the problem?
Help
Do U send the clip in question or the timeline with in-outs from the browser? Maybe u send the whole captured clip if u use the timeline as if u would chose 'capture'. Just have 4.0 but works great for me...
thanks for your resonse..
I send from the time line with the in and out selected. There is no speed changes or filters on the clips. When i "send to" motion it works great. What could it be?
do you have the clips highlighted in your timeline? or do you just have in out points set?
I've found it works fine if i have the clips selected i want to send.
M.
i select a in and out .. i have also tried to select the clip as well as create a new sequence and only put the clip i want to send in that sequence. I have tried almost everything including switching projects and edit bays.
