I try to explain it with an example. you animated an cubes position and as soon as you than change the position of the cube the key button turns yellow to show that the parameter has an other value than the fcurve. this means to me that xsi can seperate somehow this to values ( actual and fcurfe ) I wanted to use this with scripting to only set a key where the fcurve value is different to the actual.
I hope its more clear now
Sanostol
PS: I could hardly remember that i asked this question a long time ago.
