Ffalabalam - Tap-Dancing - WIP
Hey peeps,
This is my first character animation
(apart for a very bad walkcycle I did a year ago),
I am more of a techy guy.
http://www.swanimator.com/animations/ffalabalam/Ffalabalam400-240.avihttp://www.swanimator.com/animations/ffala…alam400-240.avi
Tell me what you think.
Cheers.
~SHydo
Well, considering that its your second (technically) character animation, it is very impressive.
There were a few times where the character’s center of balance was not above the feet and there were a couple popping knees and elbows, but as I said, it is excellent! better than my second character animation, that’s for sure.
Keep up the good work!
-Derick Dressel
www.BrainFaucet.com
OK man, I’m taking note, I thought I had done enough on the balancing of the body, but obviously not. I guess these things come with experience. I’m starting to get the taste for character stuff anyway so should get plenty of that. Your comment about the popping knees and elbows would be sorted out by animating the IK pole vectors I would imagine? I tried doing so, but just realised that it was just adding on even more work so gave up.
Any other things anyone might want to point out towards making my next character animation better? I don’t do any animation stuff at college, so am on the road on my own, well like 95% of you guyes anyway. So the more advice the better.
Cheers man.
~SHydo
.-Praise what you preach, preach what you praise-.
actually, a good way (not infalible) to stop joints from popping is by setting a rotation limit on that particular joint. This makes it so that the joint can’t completely straighten out when conforming to IK.
Also, I don’t know how much experience you have, but when you create your skeleton, make sure there is a definate bend towards the correct angle in the binding pose. For example, the bone coming out below the knee joint should angle slightly towards its natural bending direction.
.jesse
Ya I definitely see what you mean, actually I remember seeing that in the Primitive man tutorial, but thought it was some kind of stupid mistake.. (someone save my dumb-ass) What wouldn’t tick my clock with that was that when the character was standing fully up straight his knees would bend the opposite way, but I suppose this is sorted out with what Madlinx proposed above of setting joint limitation. It all ties in pretty well actually.
~SHydo
When I say a slight bend… I mean you model your character with the legs spread and knees straight or whatever. The legs can be in a full-standing upright position when you make your skeleton. The SKELETON (not the model) should be bent slightly… i.e. make the knee joint closer to the front of the knee to imitate bone structure. Then, make your ankle joint back a little ways so there is an angle between the knee and ankle.
Look at yourself sideways in the mirror. Your leg LOOKS straight, but if you really follow the line from your hip to your knee to your ankle, you will see that the knee joint is further forward than the other two. THIS is what I am talking about.
You should be modeling your character in an upright, spread out position. As for the skeleton… it is in fact, almost never exactly straight.
You shouldn’t NEED joint limitation on things like knees. However if you DO put proper joint limitations on every joint in your model, it will actually be difficult for you to pose it in an unnatural way!
Ya I see what you mean once again, it’s blatant to me now that the stance of a skeleton does not quite follow my preconceived perception of it.
Cheers loads for pointing these things out, it makes obtrusive sense now.
~SHydo
Main thing I noticed is that the wrists are stationary at the end when you have that breathing pose and at certain points during the animation. Seems like your Chara Setup is the cause of that problem. The waist groin area seems to level.. but that might just down to my preference…
You know when you`ve been using your computer way too much when you start thinking “Undo.. Undo…” or “Ctrl-Z” when you are writing or drawing on paper - Qt
haha thats cool, the upper body movement is just as good as below. Did you hand animate that step by step with IK? I mean for each note you animate taht step?
Excellent, cheers, deleted and added a couple of keys for them to never stay stationary, as you say the setup is a bit weird now that I re-read the primitive man tute, the wrists are not parented to the main body (which however didn’t really seem to be too much of a hindrance for the animation of them).
This if I get it right would make the pivot point of the main body too low (I don
Ya, more or less mocked the primitive man tutorial, but for tap-dancing! First I set the keys for where I wanted the feet to be during the taps (dragging feet), then their rotation, then added keys for the foot to lift in between taps (to get a tap rather than a flop) and steps, then rotated the body and translated it around for the swing mood. (but was doing it all at the same time rather than step by step). At some points there are only 1 or two frames in-between taps, but the speed doesn
