Final Gathering works by shooting rays within a sampled hemispherical area above the shaded points on the surfaces in your scene… This creates “light,” though it is not light in a traditional sense… it is simply illumination based on the color and brightness of the sampled shaded points.
The Min/Max radius paramaters control how many samples Mental Ray is forced to make when doing FG calculations.
In the simplest terms, the max radius is the distance, in units, that the renderer can “travel” through a scene before it is forced to sample a point.
Any areas in between those sampled areas are interpolated from the sampled areas to “fill in” those aresa not sampled.
The min radius tells Mental Ray that if there are any samples within this distance, they must be used for interpolation.
Essentially you are saying to Mental Ray “don’t travel more than the Max distance to take a sample, and if there happens to be a sample present within the Min distance, use it to interpolate results.”
The Max distance tends to impact render quality far more than the Min distance.
Most of the time, the higher the Min/Max settings, the faster FG will go, as it doesn’t have to take as many samples… say if your Max radius is 5, Mental Ray is forced to sample every 5 units, but if it is 50, it doesn’t have to sample until every 50th unit… that is not to say it won’t sample in between where needed, it is just not “forced” to.
Even though higher values tend to make FG go faster, shading quality is lost because less samples are being considered. That is not to say that there will be more artifacts with shading, just that there will be less “value” to the shadows… sometimes to the point of no shadows being visible at all.
So, yes, you are right that smaller values will make shading on smaller objects appear better. The Min/Max values are not a precise science, really. Even though the general rule is 10% of the scene for Max, and 10% of that for Min, sometimes you want more shadow detail than those values will give you… and sometimes that is not so important, so you might want to set it higher to go faster.
It should also be noted that when using photon mapping (GI) in conjunction with FG, less FG rays are needed and you can get away with higher Min/Max values, since when FG is used along with GI, it acts as a “last bounce” of light. Its primary purpose when used with GI is to “smooth out” the photon map result, hence you can, and should, use less photons when also using FG. The general rule for this is that, when using FG, you cast 1/10 of the required photons cast when not using FG.
I hope that clears things up some, and I hope I didn’t mess up any of the information ; )
-Steve
