Don't know about Pre-scripts
Field rendering is turned on and off in the Render Setup dialog box, in the Settings frame underneath Antialiasing.
Once rendering is done you can use the Interleave standalone from an SI command prompt to interleave the fields into final frames.
Hope this helps
jON
