For the startup for a hopefully bigger project, I've made a character with walkcyckle and other animations, I also made a set with a ground and a tree where the caracter will walk and crawl up.
My question is which workflow is the best with reference files. Can i easily make new animations, where the caracter crawls up, and ie runs on the ground, in the parent scene that I can save to the child scene file? Or what will you normally do?
Also is it normal that I can not delete or edit some or all of the objects that i've referenced? I've not locked the reference.
Thanks a lot.
