Hey
What I want to do is to link multiple FileIn to one FileIn
For exemple, let say that I have a node called MASTER and 5 other node called SLAVE1, SLAVE2, SLAVE3 and so on... When I change the source footage of the node MASTER, I want all the slave to update and use that footage too
I have put the expression :MASTER.baseFile in the baseFile option of each SLAVE node and it works perfectly. Each time I change the footage of MASTER, they update too
Heres when things get complicated. I want to make a macro out of this with only the baseFile option of the Master to be visible so that when i use the macro, Im able to choose the footage I want.
If i make the macro and do not choose ANY parameter to be editable, the macro works but of course, I cant switch footage...
If I make the macro with the basefile of the master to be visible, BANG! All red! All the SLAVEs baseFile parameter that were linked to MASTER switch to even if I havent changed the default value.
So, anyone got an idea ???
