Hi thanks for the help,
First i have put a reformat node between my read and my viewer. Yes it's works but is it not strange to need to put one.
usually if my video file comes directly from the capture, i don't need a reformat. (+ is it the reformat change somethings in my output? Quality,...).
Second what do you mean by --- your new format --- do you speak about the format in the read file? If it is, yes it's set to the right format. but it doesn't affect my viewer setting (size)
Another things that i have observed is when i open my video source in Quicktime and look the info (apple+i)
The info seems a little bit strange
Format: uncompress 10bit...., 720*576 (767*576), Millions
Normal size 767 * 576 pixels
I don't know if that comes from the square or non square pixels ?
Let me know if you see the solution.
Thanks
