Fillet and Round tool issues with smoothness
I have taken two sufaces and done either (1) Round Fillet or (2) Circular Fillet
I have set the “Advanced Tesselation” options in the Attribute editor to 50 for all the surfaces invloved i.e the intersecting surfaces and the fillet / round surface. On rendering it, I still see gaps. I tried to increase the tesselation to 150 and even though it takes a super looooooooooooong time to render that simple object, I still see the gaps.
A sample of that rendering is at the following link:
http://elworld.tripod.com/example\_02.jpg
I’m desperate to understand what’s going on.
I truly appreciate any help I can get on this issue.
Thanks!
The answer you seek does not exist, and niether does your posted image. Fillet is a math calculation that has a ‘best-I-can-do’ product. And this product is more than good enough for anything you want to do. If you need a large model with a curved edge/lip, then create it, don’t fillet it. Leave filleting to areas that will not be used in closeup shoots. And I guarentee you that after you include the rest of the scene, texture it, and light it, you will not see it anymore.
These gaps will always exist and you must find your way around it instead of fighting it. The most you need in your Tessellations is 20. And set the smooth edge to 0.999. The rest is just working around it artisticaly.
That’s just from my own experience and months of searching for the same answer. If anyone else knows better. Please speak up.
Oh yea, also you might want to make sure that the surfaces have enough spans, sections..etc so that you have smaller gaps.
Hey thanks for the info - it makes a whole lot of sense now that you bring it to my attention. I’m just super disappointed that Maya being such a fantastic program, wouldn’t have the fillet and round tools be more ‘refined’. Oh well.. nothing comes easy eh?
Sorry about you not being able to see the posted image. It turns out that you’ll have to manually copy and paste the url in your address field in the browser to view it (sorry for the inconvenience).
Thanks a ton for your reply!
Peace
Well it is possible to tesselate over the shell… Maya renderer cant do this mut mental ray standalone can!
Also if you use a micropoly tesselation then thats no problem. If you need to get close i suggest using explicit tesselation, and no smooth edge! but be carefull with this, if your precision is low enough there might be a considerable gap that will not converge because the edges are too far from eachother.
The round tool is basicaly just to complete the nurbs toolset, basicaly a throwoff from eingeneering and ID modelling. Animation or rendering wise its not necceserilya a good idea! But depends on your renderer!
I’m really not sure if maya nurbs modelers have ever needed a more refined fillet tool. Perhaps it’d be nice but its never been that much of an issue since there is so many other, much better and more realible methouds to model anything you’d need to fillet.
Becouse of that, its probably never needed to be looked into.
If you need hardcore tools like that for modeling products. I won’t use anything like that in aniamtion, its too messy, then I’d suggest you look into Alias Studio for things of that nature.
Hey… thanks guys for all the valuable input. In regards to Joojaa’s comment, I don’t have any other rendering program except Maya and whatever it provides. And in regards to jtk77’s comment about ‘other’ methods / tools to do a fillet like operation, I’d be SUPER grateful if you could tell me what those are. I’m so lost and frustrated at this point with the fillet operation and it’s rendering. If you look at the Alias website, it has a user2user tutorial of this car wheel and they mention ‘fillet’. That’s pretty much what I’m trying to do and failing to render smoothly like ‘they’ have it in the tutorial.
** p e a c e **
Well, theres no reason why you cant get maya to tesselate it so that the seams arent visible! But youd real realy have to understand how the renderer works to understand the whys and hows.
First imagine the renderer as a screen with holes in it each hole is infinitely small and a number of theese represent the pixel and they are summed together. Now, if the tolerance is small enough (mind you the default tolerance isnt especialy if you work in cm scale), smaller than a given pixel size! And your teselation is very fine so that the gaps are smaller than a pixel. Youd get an effect where the seam is invisible. Also if you supersample the shading then the likelyhood of any artifacts showing up reduses dramaticaly.
Altough the sudden change of curvature will still be visible to the human eye altough the seam isnt! Remeber if you work at bigger size the results will be easier to handle, since edge smoothness is size debendent (no it doesent help to scale the matrix it must be frozen!). You want a demo. Aldo dont ind how the wievport looks like.
Hey thanks for taking the time to explain the ‘behind the scenes’ for rendering. It all makes a lot of sense now. I did follow your advice and there has been a significant change in the rendered results (not completely seamless, but very close). Thanks a lot for your help and advice.
. . * * p e a c e * * . .
One of the other techniques I mentions is refered to as
“patch” modeling, You would make several srufaces to create a complex surface, if done correctly it’ll be seamless. Maya has stiching utlities that help as well.
Hey jtk77 .. thanks for the info. Yes, I am familiar with ‘patch modeling’ but at this point and for this particular model, it may be too much to get into that detail level of modeling although for close up shots I will definitely consider it. I have just one question about the patch modeling bit, how can I get one single image texture map to show across multiple patches.. example: say I have a logo that I want to apply to several patches in a way that I see that one logo only over those patches, how would I do that? Right now when I try to apply a logo texture map to several patches, the logo appears on ‘all’ the selected patches.
I hope my question makes sense.
