I have a custom outlinerEditor with an itemFilter that is filtering out all texture file nodes whose file paths match a certain regular expression. Now my question is how to get the itemFilter to dynamically update so that when I change the file path of one of these nodes, it will re-evaluate the filter and add/remove items from the outlinerEditor dynamically. I've tried attaching the filter to a selectionConnection node (something Alias "strongly discourages") instead of connecting it directly to the outlinerEditor, but this doesn't work. So here's the code I've got right now:
global proc int badPathFilter(string $name) {
if (objectType $name == "file") { // file texture nodes
string $path = getAttr ($name+".ftn");
if (!gmatch($path,"C:/*"))
return 1;
return 0;
global proc showBadPathWindow() {
string $nodeFilter = itemFilter -byScript badPathFilter;
string $attrFilter = itemFilterAttr -byNameString "fileTextureName";
window;
frameLayout;
string $panel = outlinerPanel;
string $outliner = outlinerPanel -query -outlinerEditor $panel;
outlinerEditor -edit
-filter $nodeFilter
-showAttributes true
-showAttrValues true
-attrFilter $attrFilter
-autoExpand true
-showDagOnly false
-ignoreDagHierarchy true
-showNamespace true
-highlightActive true
-dropIsParent false
$outliner;
showWindow;
