RC 0.2 warn 082066: filtering and contour rendering are incompatible
RC 0.2 warn 082035: sample filter switched to box 1.0 1.0
im sorry can you explain this a bit more whats happening here, im having the same problem im not sure what to do my images are rendering so its not a fatal error but just want to know better what this means?
or let me be a bit more specific… Im also getting this issue with calculation Motion Blur… which in the maya help says that they are incompatable… well im not sure where im invoking contour rendering… Is it in the shader? or the render settings how do i turn contours off? My scene is a collection of lots of ellements so im not sure where this problem is comming from? how would one suggest i debug this?
Contour rendering analyzes your frame buffer for change, now whenever you render a frame buffer image the signal is reconstructed using a multi pixel filer to make it continuous (the one in render globals). However contour rendering operates on those pixels so bleeding colors form pixel to pixel makes little sense for the edge detection algorithm. So its not supporting any other re constructor than a box one thats smaller then one pixel which does not bleed!And switches the filtering to box if its other than box.
Either turn contour rendering off or dont reconstruct the signal with bleeding convolution kernels.
Ok thank you for the description there Joojaa, makes more sense to me now why you cannot use gaussian or other filters that blend over multiple pixels. However I do have contour rendering turned OFF in the render settings.. and its still trying to do a contour render somewhere, so I’m wondering how/where that is and how to stop it! I’m not sure its probably something I’m doing inadvertantly…
Ok so I have exported all my elements then imported them into a new “clean” scene and it is NOT giving me that contour render error anymore… so i imagine by doing that I got rid of whatever node was causing the render to try to render contours.
seems like 90% of the time if i just export my elements and bring them into a new scene things run much much smoother.
