Ok
Does anyone know a better way than CMX edls to bring a FCP project into premiere.
Does any opne know anything about Automatic Duck "premiere pro importer.
cheers
use version 1 xml data on fcp sequences. xml is hard to figure out but try reading up on it a bit cause it seams to work for me. I use both premiere and fcp at work and i have some of the same problems. xml wont take all your clip attributes so you can control them but you can certainly keep the clips in order
